Discussion topic: Sky Q to Bauhn tv volume
Message posted on 29 Apr 2025 10:57 AM
Since moving home sky Q control volume button no longer works
Message posted on 29 Apr 2025 11:01 AM
Re: Sky Q to Bauhn tv volume
Hi @Shelly1971
Try LG in the set up also Other brands
Message posted on 29 Apr 2025 11:06 AM
Thanks tried all the 7-9, 1-3 Bauhn, Toshiba, LG, Logitec, bew batteries everything I can think of
Message posted on 29 Apr 2025 11:13 AM
Did you try Other brand category @Shelly1971 ??
Message posted on 29 Apr 2025 05:13 PM
Yeah.. i don't understand because the controller with our Samsung works fine.
