13 Aug 2024 11:25 AM
From Power On on the remote to the screen appearing is taking minutes each time.
Have completed box software upgrade and all the usual resets but problem is continuing.
We have one of the first 2TB boxes.
Does this need replacing and if so are Sky likely to help?
Thank you.
13 Aug 2024 11:37 AM
Thank you.
Hi @violetmo
Have you tried a Reset Settings in the Q box hidden menu?
If the issues continue then it's best to contact Sky for an Engineer to check your Q box.
