Discussion topic: Sky Q ….taking ages to change channels
This message was authored by: TomQless
It can take 5 seconds to change a channel on my Sky Q box
Re: Sky Q ….taking ages to change channels
@TomQless
What have you tried? Have you rebooted the Sky Q box?
Hi @TomQless
This message was authored by: GemS2020
I have the same, last night a rebooted, reset and still no joy. Anymore recommendations thanks
This message was authored by: Frances9
Thankyou for your post. It has resolved issues I was having
