Discussion topic: Sky Q switches itself off when turning it on 1st time
This message was authored by: type-r
Minor but strange issue.
I recently upgraded to a new (refurbished) Sky Q box v2 (external brick PSU version) from a 2016 v1 box.
Before, I'd turn the Sky Q box on using the remote, which would automatically turn the TV on also. Now, I turn the Sky Q box on, TV comes on also but after about 5 seconds, the Sky Q box switches itself off automatically. TV remains on. I then turn on the Sky Q box again with remote again and this time it stays on.
Any ideas?
Re: Sky Q switches itself off when turning it on 1st time
Any ideas?
Hi @type-r
Assume you have checked it is on the latest Software?
Also
Avatar for type-r
Level 4 icon
Thanks @oldfella however reset did not resolve the issue. I have also turned the Standby Mode within Settings from Eco to Off but this has also has no effect.
Hi @type-r
Just as a test try switching the Television on before switching on the Q box.
Avatar for type-r
Level 4 icon
@oldfella Yes that works. Downside, is that it now requires two presses as opposed to one and the TV one requires to press and hold to switch it on, so whole process is not "instant" like it used to be. First world problem for sure but still a tad bit annoying that it's not working like with my previous Q box.
Hi @type-r
It looks like something with the Television powering on that is causing it.
What breed is your telly?
Avatar for type-r
Level 4 icon
Thanks @oldfella - it's a Samsung. I'll take a look at the settings to see if anything is set to ECO mode or to set sources to standby after X seconds etc.
