Discussion topic: Sky Q suddenly gone to pot!
This message was authored by: Danderso
We're just back from hols. All good before we left. Some recodings we set were not picked up, a few that did record now say they are not accessible/dont exist tho they did dhow on planner. Cant get to acess list of recordnings now., spinning wheel ony. Second Q box not connecting properly.
Re: Sky Q suddenly gone to pot!
Hi @Danderso   Have you tried a power reboot of the Main Sky Q box?
@Danderso
As suggested by @MightyQuinn try a reboot of the main Sky Q box, then once that’s back up and running do the same with any mini boxes if applicable -
~ press the 🏠 button
Allow 5-10 minutes before things hopefully revert back to normal.
NOTE: I only provide help on the forum boards and NOT via Direct Messaging so DMs are switched off
Avatar for Danderso
Thanks both. Have already tried that. No improvement.
