Discussion topic: Sky Q stuck on yellow light
This message was authored by Simo89 This message was authored by: Simo89
Hi, my Sky Q box is stuck on yellow and I'm not sure how to fix it. I've tried pressing the restart button but that doesn't seem to fix the problem
This message was authored by lettice This message was authored by: lettice
Re: Sky Q stuck on yellow light
Try following the recovery procedure on Step 3 in this help article;
https://www.sky.com/help/home/sky-tv/sky-tv-q/fixing-sky-q/fixing-q-equipment/sky-q-box-wont-turn-on...
Simo89
Unfortunately that didn't work
This message was authored by Fergus+MacRoth This message was authored by: Fergus+MacRoth
Ever since I got my last Q box (a replacement for the original faulty one), I periodically had the same issue you have described.
Usually, unplugging it, then plugging back in, and going through the Welcome screen fixed it. A minor pain, but it worked.
More recently, that didn't work anymore, and I had to do the reset (holding the reset button whilst powering on. That worked three times over four days, but I called Sky on the third time (knowing there was a real problem) and they immediately sent out a new box. That arrived on the fifth day (less than two days after it was ordered), by which time the reset didn't work on the old box one last time.
You've got to call Sky.
FM
