Discussion topic: Sky Q stopped connecting to router and wifi
This message was authored by: problems23
We have had the sky Q box for over 4 years, nothing has changed, but it has lost connection with the wifi.
It used to disconnect with the router every now and then, but using the network reset in settings would work.
However today it just isnt working. I have spent over two hours trying to use all the previous suggestions on the forum.
Have tried so far,
using the wps buttons on both,
switching off and rebooting sky Q
switching off and rebooting router
using network reset, but it just doesnt work
have moved the router as close as i can get it, ( within 2 metres of the tv with no walls between it.
any suggestions would be very welcome, as this means we have not been able to use our apps, and skystore tonight which is frustrating as we had a movie night planned with the children.
This message was authored by: Greenfingers001
Re: Sky Q stopped connecting to router and wifi
This message was authored by: Lisa-P1987
We are still looking to help you problems23. If you need our support let us know and we can re-escalate to our chat team. Your invite has been closed now. Thanks
Lisa - Sky Tech Team Expert
This message was authored by: leedsdad
Did you get a solution to this as exactly the same thing has happened to us.
