Discussion topic: Sky Q still switches off
Message posted on 21 May 2025 09:20 PM
Still having issues with Sky Q box turning itself off. Have followed the advice from Sky but it's not worked.
Message posted on 21 May 2025 09:26 PM
Re: Sky Q still switches off
Hi @Gb44
Try a Reset Settings in the main Q box hidden menu.
Message posted on 21 May 2025 09:45 PM
Ours has started again tonight. Three times in last couple of hours
