Discussion topic: Sky Q slow to load channels or and slow to down
This message was authored by: dazeo
My sky Q box is getting slower to load channels or download stiff , even  loading  apps takes for even that if it works at all , i reboot it and the wifi the signal to the box is good as i check it on the app , does anyone have any ideas what i can try next
Re: Sky Q slow to load channels or and slow to down
Hi @dazeo
First check your Disc space in Recordings - Manage just to make sure it is not reaching capacity.
If all looks OK
