Discussion topic: Sky Q shows green light and blue Q but no picture
Message posted on 10 Jul 2025 09:46 AM
Hi, so for a few weeks now particularly the next morning after the box has been off all night, when we try and turn it back on it goes to the green light on the box and the blue Q is rotating indicating it's on. However it isn't acutally on and there is no picture. The only way to do this is to switch it off at the mains and resetting it. We have to do this at least twice a week.
Any help appreciated, thanks.
Message posted on 10 Jul 2025 10:47 AM
Re: Sky Q shows green light and blue Q but no picture
Who is your broadband with?
If EE, check out this thread: https://helpforum.sky.com/t5/Sky-Q/Sky-Q-box-crashing-amp-box-fan-spinning-loudly-EE-Broadband/td-p/...
LG B6 OLED 55” | LG UP75 LCD 43” | sky Q | sky Q Mini | sky Mobile | sky Soundbox | EE Apple TV 4K | EE Full Works FTTC
Message posted on 10 Jul 2025 11:13 AM
Hi @Garton90
Message posted on 10 Jul 2025 11:26 AM
@Garton90 wrote:Hi, so for a few weeks now particularly the next morning after the box has been off all night, when we try and turn it back on it goes to the green light on the box and the blue Q is rotating indicating it's on. However it isn't acutally on and there is no picture. The only way to do this is to switch it off at the mains and resetting it. We have to do this at least twice a week.
Is it simply a case of the TV not automatically changing to the correct HDMI source? Have you tried manually going through the HDMI sources.
Sky Community Forum SuperUser
Former Sky+HD Beta Tester
