Discussion topic: Sky Q remote won’t turn tv off
Message posted on 27 Oct 2023 09:42 AM
My remote works fine but will not turn tv off.
Message posted on 27 Oct 2023 09:53 AM
Re: Sky Q remote won’t turn tv off
You have to hold the power button for about 2-3 seconds.
If that's not working then the remote isn't coded correctly.
Message posted on 27 Oct 2023 10:04 AM
As mentioned above, hold down the Sky Q power button for 2-3 seconds.
If it worked before, you may need to reapir your remote again as described in this help article;
Sky Q remotes | Sky Help | Sky.com
Message posted on 23 Nov 2023 04:18 PM
Still can't get remote to turn tv off
Message posted on 09 Sep 2025 03:54 PM
I have same issue. Remote was ok for about 2 weeks after switch to Sky Q by Sky technician. Then after switching off by holding button down it goes off but after a few seconds restarts.
Message posted on 09 Sep 2025 04:24 PM
I have found that be keeping off button pressed for about 5 seconds it does the trick
