Discussion topic: Sky Q remote won't control JVC LT-24CR230
This message was authored by Burnsyboy This message was authored by: Burnsyboy
Hi, I've tried all of the codes provided, but I can't get our Sky Q remote to control new LT-24CR230 JVC television. Any ideas. Thanks
Re: Sky Q remote won't control JVC LT-24CR230
@Burnsyboy
I believe the Roku OS JVC range is very new, so there may not yet be a working Q remote code.
This message was authored by Laing1 This message was authored by: Laing1
@Burnsyboy have you tried the Vestel codes
Burnsyboy
Thanks for the tip but just tried the Vestel codes and no luck unfortunately.
This message was authored by Minimog This message was authored by: Minimog
I just fixed this issue with my new TV (model LT-40CR340) and found if I select Polaroid, one of the options actually worked!
Give it a try, might be using the same setup.
I found something strange today...I just received a new sky Q remote (voice control stopped working on the old one), but the new one will not control the new TV!
This message was authored by Ecosse This message was authored by: Ecosse
Try these:
0681, 2704, 1846, 3747, 2146, 0681, 0536, 0634
Good luck.
Samsung UE49MU7070XX - Samsung MS550 Soundbar+ with 9000S Rears
Sky Q 2Tb + 3 Minis - BT Full Fibre 900
The Sky Q box I have doesn't use codes.
@Ecosse wrote:
Try these:
Good luck.
@Ecosse as @Minimog says bluetooth remotes don't use codes and probably 90% of the Q remotes or more are bluetooth the old remotes supplied with mini boxes were only IR and they used codes but Sky stopped supply IR only remotes a long time ago
This message was authored by majorcart This message was authored by: majorcart
Roku find the first one it works only for the volume
