11 Dec 2023 03:11 PM
11 Dec 2023 03:15 PM - last edited: 11 Dec 2023 03:16 PM
I believe the Roku OS JVC range is very new, so there may not yet be a working Q remote code.
11 Dec 2023 05:13 PM
@Burnsyboy wrote:
Hi, I've tried all of the codes provided, but I can't get our Sky Q remote to control new LT-24CR230 JVC television. Any ideas. Thanks
@Burnsyboy have you tried the Vestel codes
11 Dec 2023 05:45 PM
Thanks for the tip but just tried the Vestel codes and no luck unfortunately.
04 Jan 2024 05:18 PM
I just fixed this issue with my new TV (model LT-40CR340) and found if I select Polaroid, one of the options actually worked!
Give it a try, might be using the same setup.
08 Jan 2024 05:42 PM
I found something strange today...I just received a new sky Q remote (voice control stopped working on the old one), but the new one will not control the new TV!
08 Jan 2024 09:19 PM
Try these:
0681, 2704, 1846, 3747, 2146, 0681, 0536, 0634
Good luck.
08 Jan 2024 09:34 PM
The Sky Q box I have doesn't use codes.
08 Jan 2024 09:56 PM
@Ecosse wrote:
Try these:
Good luck.
@Ecosse as @Minimog says bluetooth remotes don't use codes and probably 90% of the Q remotes or more are bluetooth the old remotes supplied with mini boxes were only IR and they used codes but Sky stopped supply IR only remotes a long time ago
05 Sep 2024 11:41 AM
Roku find the first one it works only for the volume
