Discussion topic: Sky Q remote will not pair with new tv
This message was authored by: Tom319
Sky Q remote will not pair with Hisense A6Q 55" LED 4K HDR Smart TV -55A6QTUK.  0206 code does not work.
Re: Sky Q remote will not pair with new tv
Hi @Tom319
If you have a Bluetooth redone with Boice control and a microphone button, then they do not use codes.
They use Brand and Model.
If you brand isn't shown try Other brands.
Avatar for Tom319
Hi Old fella
Thanks for your reply.  Unfortunately that has not worked.  But thanks for your help.
