Discussion topic: Sky Q remote volume inverted when used with TCL C741K
This message was authored by: phil+mo
This is very frustrating  - volume inverted on Sky Q remote. Used code 2703.
Have seen thread : https://helpforum.sky.com/t5/Sky/New-TV-TCL-43C-645K-need-remote-code-for-SKY-HD/m-p/4457877
So clearly I'm not the only one.
Any help would be great.
Re: Sky Q remote volume inverted when used with TCL C741K
@phil+mo
That other thread is for Sky+ not Sky Q.
Avatar for phil+mo
Ah thanks @Daniel0210
Maybe not related in that sense though - hopefully there is a Sky Q solution somewhere.
Hi @phil+mo
All latest Q remotes are Bluetooth and use TV Brand for pairing and codes
Assuming you are using a Q Bluetooth remote (all Q Bluetooth remotes have a microphone button):-
Try completly resetting your Bluetooth remote.
