Discussion topic: Sky Q remote voice control only works occasionally
This message was authored by: lynnechapman265
Hi, when I try to use the voice command on my remote control for my Sky Q minibox, it rarely works. Mainly I get "Sorry, we didn't quite get that". I've tried new batteries etc but it doesn't help.
Thanks for any advice or help.
Re: Sky Q remote voice control only works occasionally
@lynnechapman265 you could try reboot your router then doing the same with your main Q box
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Avatar for lynnechapman265
Many thanks, I have already tried that.
I find it works amazingly well. I do try to speak like Hugh Grant though.
hi @lynnechapman265
Have you checked that the microphone is not blocked ?
(Small hole below the SKY Logo/button)
If necessary try cleaning carefully with a pin
@Chodley 🤣works fine with my scottish accent 🤣
