10
This discussion topic has been answered Discussion topic: Sky Q remote to control a Fire TV Series 4
This message was authored by: g424ahe
I have a new Fire TV series 4 (not a firestick) and can't find a working remote control code so that I can turn volume up and down using my sky q remote... anyone know if this is possible?
Avatar for g424ahe
This message was authored by: g424ahe Answer
Re: Sky Q remote to control a Fire TV Series 4
Bingo! Had to go through a bunch of the JVC codes but eventually one worked.
This message was authored by: SaintCW
I'm also having the same issue with my fire TV series 4 and would appreciate if anyone knows how to do it!
This message was authored by: JamesB1984
Just got the series 4 firetv. Had the same issue as others. Found through another forum that the series 2 tv's use JVC codes. Tried the first JVC code and BINGO, all working. Hope this help.
Avatar for g424ahe
This message was authored by: Pets1703
Thank you for this!
I just got the Fire TV 4 myself.
I went through the Sky setting/setup/remote and told it I was using a JVC TV and it got it first time (1 out of 25 options)
 I use Amazon a lot so it seemed the wisest choice to use thier TV too and integrate with Alexa.
This message was authored by: H0v1s
Thanks worked first time as suggested
This message was authored by: jaycoo
Can someone psor the code used please
Hey
From memory, when going through the menus on the sky remote, the instructions on the TV just say it is "trying the 1st code, did this work?"  I don't remember it giving me a code. I just followed the prompts on the screen.
Hope that helps
This message was authored by: Muhit0
3075 worked for me
This message was authored by: BANKSY3
3075 worked for me two.
This message was authored by: p1ntplease
I've just bought a Panasonic  TV-32S55AEY and JVC worked for me. Thank you.
