Discussion topic: Sky Q remote control of TCL 55C835K
This message was authored by SaintJB This message was authored by: SaintJB
Hi is anyone aware of a compatible code to get the remote to control this TV?
When I try the first one on the TCL list, the remote controls volume and power but will only select inputs but I cannot navigate to the correct input to change it on the TV.
Thanks for any assistance.
This message was authored by Mark39 This message was authored by: Mark39
Re: Sky Q remote control of TCL 55C835K
Have you tried pressing the Input button repeatedly to see if it then moves between the options?
SaintJB
Hi Mark, yes the input button opens and closes the input selector but I have no way of navigating on the sky remote as the direction keys on the sky remote do not move the input selection as they do on the TV remote.
This message was authored by RichE60 This message was authored by: RichE60
Hi - I have the same problem, none of the TCL codes work for the long press TV off function. A work around is to press the Sky power button for a short count to 2. This works most of the time for me, but not always.
COME ON SKY - TCL TVs are now mainstream and available at all retailers
SaintJB
@RichE60 Yes I have the same, 2 second press works most of the time though not always as it sometimes bringsup the TV menue to ask you to confirm with the TV remote.
