Discussion topic: Sky Q remote batteries have failed - but cannot find correct replacements!!! they are called OEM
Message posted on 27 Mar 2023 12:00 PM
Cannot get replacement batteries for SKY Q remote!!! AA and AAA do not fit/work but OEM batteries that have failed cannot be bought retail !!!!! WHY?
Message posted on 27 Mar 2023 12:04 PM
Re: Sky Q remote batteries have failed - but cannot find correct replacements!!! they are called OEM
A standard Sky Q remote takes 2 x AAA batteries.
Message posted on 27 Mar 2023 12:05 PM
All Sky Q remotes take standard AAA batteries @Jenny+Baker+Auste
Insert the negative (-) end first then the positive end.
Message posted on 27 Mar 2023 12:17 PM
@Jenny+Baker+AusteBy do not fit, do you mean will not work or won't go in. Some batteries usually cheap ones have insulation that wraps round the -ve end of the battery a bit this prevents the -ve making contact. I have had no problems with Duracell batteries fitting or working.
This video may help.
