Discussion topic: Sky Q regular need to reset query? Advice appreciated.
This message was authored by: Chris290668
As the title say really.  Got to the stage where at least once, maybe twice a week I'll switch Sky Q on and the light just sticks on amber.  I'll turn it off at the wall and it always comes back but it's becoming a bit of a pain to keep resetting it.  Quite an old box, fully updated, have changed batteries in remote, but for some reason this keeps happening.  Suspect Sky may send a new box but that would mean I would lose all my recordings.  Any ideas why this might be happening?  Thank you.
Re: Sky Q regular need to reset query? Advice appreciated.
Hi @Chris290668
Avatar for Chris290668
Level 2 icon
Many thanks, I'll try that next time it happens.  👍
