Discussion topic: Sky Q recordings marked as series appear as individual recordings without grouping
Message posted on 28 Jan 2025 01:34 AM
In the last few weeks, recordings of series (e.g. Coronation Street, Eastenders etc) on different nights do NOT appear under "Recordings" as grouped items. Instead they appear all over the recordings list as individual recordings!
Even worse, many of the recordings simply show the channel recorded, but a blank indicative picture, or -even worse - a totally different picture from another program!
I checked the software and it's current, but just to be sure performed a software update anyway.
Surprise, surprise - no change!
Any recommendations?
I'm loathe to reset everything to factory settings as I'd lose recording planner details, all recorded programs, any changed settings, and so on?
However, if that's the only way, then .........
Any help gratefully accepted!
Kindest regards,
Alan
Message posted on 28 Jan 2025 03:35 AM
Re: Sky Q recordings marked as series appear as individual recordings without grouping
@Dwile+Flonker
Try a reboot of the main Sky Q box, then once that’s back up and running do the same with any mini boxes if applicable -
~ press the 🏠 button
Allow 5-10 minutes before things hopefully revert back to normal.
Message posted on 28 Jan 2025 11:34 AM
Thanks Daniel but that was the first thing I tried?!
OK, only on main box, and not the mini box upstairs, but - according to Sky technical dept - that box only reflects the main box, mirroring the info via Wifi.
Message posted on 12 Jun 2025 09:50 PM
Have the same problem. I have tried the reboot method but nothing changes
Message posted on 24 Jun 2025 09:35 PM
I have the same problem, this started happening recently across multiple programmes, programmes which were previously collated into groups based on the series.
Message posted on 29 Sep 2025 10:09 AM
I have the same problem, it has just started in the last week or so.
