Discussion topic: Sky Q picture quality seems inferior to Sky HD
Re: Sky Q picture quality seems inferior to Sky HD
@Paul401 wrote:
OP i nearly drove myself mad trying to max out my sky settings and give me that lovely sharp picture and nice clear sound which i assumed i would get with sky, it doesnt exist as far as i can see & ive seen other sky users houses as well, dont even get me started on the sky response to questions like that, lets just say total waste of time, the signal is just not good enough to do that imo & they wont boost it either no matter what u might say, i just accepted this in the end & got as much of a discount as possible on package
They can't boost it. It's not their satellite for a start. And it would only help people who are getting picture breakup or blank channels, most of whom resolve that by re-aligning their dish.
This message was authored by: Paul401
I'm currently using some generic hdmi cables i purchased from an electrical store for less than 15 each years ago, i compared them and others i had to several branded names i purchased from amazon running my tests. I realised i got lucky with these cheapo cables as they compared equally with cables costing multiple times what they did & and the sky cables provided were average to me. They can certainly be improved and by quite a lot too. My conclusion is that u will have to test out quite a few different cables and u will know when u get one u like as u can compare like to like in front of your eyes and ears. I only used amazon as their return policy suited what i was doing at the time. This is quite a few years ago too so not sure if things have changed now. You may get lucky with cables from a local store which are cheap and look well made, its trial and error type of thing im afraid.
You didn't get lucky. You got what we all get. They either work the same or they fail to get a picture through..
The main issue with sky picture quality is compression artefacts, most visible on large screens, and that is down to them minimising money spent on satellite bandwidth.
@Robert35 wrote:
If you speak to the guys at the futureshop they tell me that they can make a big difference. They sell all types of cables from hi-fi to tv you name it, they are probably the biggest suppliers in this country
Ah, yes, the people who claim insulation is directionally biased in order to retail HDMI cable at £2000 a metre...
idk what to say, really u must have poor eyesight and ears is all i can think of
i like my amps and receivers and have done for years, i know good sound and picture quality, sky is NOT it, u have your opinion i have mine i guess
@Paul401 I really don't think there is any need for that the first rule of the forums is "Be nice to each other" which that is not
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Avatar for Robert35
Level 2 icon
This message was authored by: Robert35
No of course not but I bought some chord speaker cables from them some years ago and what an improvement from the Qed ones
Analogue signals do behave rather differently...
I don't know who this was directed at? I said Sky's compression is a problem for their image quality. I also said Sky Q was not worse image quality than SkyHD. I didn't say it was great. UHD HDR stuff on Sky is ok but 4k blurays are far better.
As per my earlier comments. Analog and speaker cables are worth investing in. To a point.
😮 that should be illegal
@Chodley
I particularly enjoy the 'directional' and 'mechanically tuned' ethernet cable which they also offer, at over £3000 a metre.
The descriptions of things like the AudioQuest range do have a strange kind of poetry, and there are some superb 'reviews' on Amazon of all the other wonderful powers they have, including enhancing virility and generating world peace.
Well visiting there was an eye-opener.
I have tried writing a few of my thoughts but decided none would probably be within the Community rules  - I will just say  I find it quite unbelievable
Avatar for Robert35
Level 2 icon
You have to be sensible you don't have to buy a top of the range cable for a £1300 pound television you might want to if you were getting one for £30000
Avatar for Robert35
Level 2 icon
That's true
