Discussion topic: Sky Q not working or maybe the remote
This message was authored by: Jackie0903
Sky's box was working pressed the controller and now unable to activate the box I have unplugged but still not working
Re: Sky Q not working or maybe the remote
Hi @Jackie0903
Have you tried pressing the Standby button (Amber led) on the front of the Q box.
If this turns the Q box on
Try completly resetting your Bluetooth remote.
Then make sure that you are pointing your remote at the Q box and press 1 & 3 together until the led flashes and follow onscreen instructions to re- pair.
