Discussion topic: Sky Q not connecting to wifi
Message posted on 05 Jun 2024 07:33 AM
Sky Q not connecting. Reset and restart and tried wifi button but just spins and doesnt connecf
Message posted on 05 Jun 2024 11:34 AM
Re: Sky Q not connecting to wifi
Hi @McGregor123
Assume this is your main Q box.
