Discussion topic: Sky Q not connecting to sky broadband
Message posted on 01 Jun 2024 07:38 PM
It seems to be a common issue, our Sky Q box isn't connecting to sky broadband having tried multiple times to connect via resetting WPS and following network reset steps on the box
Message posted on 01 Jun 2024 07:46 PM
Re: Sky Q not connecting to sky broadband
Hi @TashaB22
Try again after resetting the router.
On Sky broadband hold the Reset on the back of the router until the power light flashes green (about 10 seconds). Don't unplug or switch off your router while it resets. The power light will go green when it's done.
On Sky Broadband you will be asked to press the WPS button on the Sky router. (Not on the Q box as the Network reset will start the main Q box WPS automatically). Make sure you press the WPS button on the Sky router and not the reset button.
