Discussion topic: Sky Q not connecting to Sky Broadband
Message posted on 17 Jun 2025 07:41 PM
I recently received one of the new routers from Sky.
Since then we have had intermittent problems (usually early evening) where there is no connection to Sky Broadband from Sky TV.
We have been round and round in circles following and completing all on screen instructions. Rebooted tv and rebooted Sky router. Nothing ever works until all of a sudden it connects like magic and then works fine until the next time it disconnects.
On friday it the onscreen gave me an option to request an engineer. On monday an Openreach guy came and went through out connection and main box on street. Finally they said it was fixed. Lo and behold Monday and Tuesday evening the same fault appeared. Round and round for 3 hours trying to connect Q to broadband. On the umpteenth attempt it connects.
i am 100% sure the router is faulty.
Cant speak to Sky as that just sends me round in circles too.
any ideas?
Message posted on 17 Jun 2025 09:05 PM
Re: Sky Q not connecting to Sky Broadband
Have you got minis? How far apart are the router and Q?
Message posted on 17 Jun 2025 09:16 PM
Yes i have 3 minis. The router and q box are approx 30 feet apart in separate rooms separated by a hallway. I also have two boosters set up.
Never had this issue with previous router that Sky advised me to change.
Any suggestions gratefully received
Message posted on 17 Jun 2025 09:21 PM - last edited: 17 Jun 2025 09:21 PM
The old routers worked differently with Q.
where are the boosters? Are they Q specific ones (good) or Sky ones (bad)? Have they been WPS re-synced to the new router? Might be worth hard-wiring one to the router.
Message posted on 17 Jun 2025 09:21 PM - last edited: 17 Jun 2025 09:22 PM
Assume they are Sky Q WiFi boosters @Derbyphil27
Reboot the minis as above.
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box. If you do this make sure you press the Sky router WPS button and not the router reset button. If you have the new Sky Max router then you need to connect the WPS to the main Q box.
If you get the first mini connected then for other minis use WPS on the nearest Q device (main Q box or Sky Router (not Sky Max) if on Sky Broadband or previously connected mini).
Message posted on 17 Jun 2025 09:42 PM - last edited: 17 Jun 2025 09:50 PM
Fundamentally the problem is that the Max Hub doesn't have the proprietary wireless components and software stack which were built into the Q Hub and Sky Broadband Hub to facilitate their participation in the 'Q mesh'. WiFi Max (2023) is essentially a Comcast product intended to optimise connectivity to Glass and Stream, while Q (2016) was developed when Sky was an independent company.
