Discussion topic: Sky Q not connecting to BT hub
This message was authored by: Cat71
Sky Q box not connecting to BT hub. I've tried everything suggested in forums. Full reset of box, reset of router but nothing.
no mimi boxes involved
im at a loss now
Re: Sky Q not connecting to BT hub
im at a loss now
Hi @Cat71
On 3rd party broadband and your router does not have a reset button, reboot it by disconnecting the power lead for 30 secs and then reconnecting.
3rd party (non Sky ) broadband then you need to enter the SSID and password for the router 2.4 Ghz WiFi band.
