Discussion topic: Sky Q not accepting wifi password
Message posted on 28 Jun 2023 08:15 PM
We got a message to say there was no internet connection on Sky Q even though other devices are working online through the wifi. We tried putting in the password for the network in again but it won't accept the password which is correct and we have tried multiple times but each time Sky Q does not accept the password and says in is incorrect. We have tried rebooting Sky Q as well as our hub but each time its the same. What do we do?
Message posted on 28 Jun 2023 08:36 PM - last edited: 28 Jun 2023 08:41 PM
							Re: Sky Q not accepting wifi password
Hi @Rousee
Assume you are on 3rd party Broadband and not with Sky.
The Q box needs the SSID and password for the router 2.4 Ghz band.
Who is your Broadband supplier?
Message posted on 29 Jun 2023 07:40 PM
Does the router have a wps button? If yes then you can click this then click the wps button on the front of the Sky Q box to automatically set up the Wi-Fi connection.
I don’t work for Sky.
If I have helped then please leave a like.
Message posted on 29 Jun 2023 07:46 PM
That's only if you are Sky Broadband @twilight+princess
With 3rd Party broadband you have to use SSID and password for the router 2.4 Ghz band.
Message posted on 29 Jun 2023 07:54 PM
I have to disagree there @oldfella I have Virginmedia & used the wps button to set up the Wi-Fi connection due to the Sky Q box not accepting the passphrase.
Message posted on 29 Jun 2023 07:59 PM
Dont know how you have achieved that .
See following link
https://www.sky.com/help/articles/setting-up-sky-q-connect-to-third-party-router
Message posted on 29 Jun 2023 08:03 PM - last edited: 29 Jun 2023 08:07 PM
Thanks for the link. It states that you shouldn't use wps rather than you can't use wps.
It's worth trying imo.
Message posted on 29 Jun 2023 08:09 PM
I suspect all routers will have a WPS button but you cannot normally use it to connect a Q box unless you are on Sky Broadband with a Sky Hub
Message posted on 29 Jun 2023 08:10 PM
Must've been a fluke the 2 times I've done it.
Message posted on 02 Dec 2023 03:57 PM
I can't use my password on sky, it is correct, but it won't hav any off them, my own, and the fibrus one.
