4
This discussion topic has been answered Discussion topic: Sky Q - no volume control when viewing on LG 48A2 OLED
This message was authored by: 2greens1red
I've been setting up my Sky Q with a new LG 48A2 OLED TV.
Everything appears to function except volume control is only available on the LG remote, and not on the Sky Q remote. I've explored settings on the LG and Sky, but not finding a solution.
Hopefully there's something I've missed?
This message was authored by: nigea99 Answer
Re: Sky Q - no volume control when viewing on LG 48A2 OLED
hi again  @2greens1red
I forgot to say follow the onscreen instruction after pressing 1 & 3
It is quite likely that if your TV is very new  the model may not be listed.
Anyway, I usually suggest people just choose the 'Find it For me' option which cycles through the most used codes for the manufacturer
hi @2greens1red
you will need to pair your remote to your new TV.
I suggest you first reset your remote :
Press & Hold the 7 & 9 until the remote's light flashes 4 times to reset
Then press 1 & 3 together to go through to re-pair  with the box and to your TV  - make sure it has line of sight of the box as until it is paired it uses Infrared
Avatar for 2greens1red
Level 3 icon
Many thanks, @nigea99 - I'll give that a go and report back.
Level 3 icon
That's worked perfectly, @nigea99 - many thanks!
The volume control also appears compatible with a Denon sound bar.
Answered - Go to Answer
