Discussion topic: Sky Q no satellite signal
Message posted on 30 May 2025 03:08 PM
During the past week I have been getting a distorted picture or message 'no satellite signal'. Wind has been quite strong over the past 7 days but having had Sky for over 10 years I have never experienced such a lengthy problem with my tv before.
Message posted on 30 May 2025 03:17 PM
Re: Sky Q no satellite signal
@littlebourne5
If you’re seeing a “no satellite signal” message check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Otherwise it’s very likely a dish misalignment or possibly a failing LNB (on the arm of the dish) so check the troubleshooting on this link
It’s worth noting that:
