Discussion topic: Sky Q miniboxes not able to join the network
Message posted on 05 Jun 2024 10:12 PM
Earlier today was on the phone to Sky about my broadband performance which has gone right down hill over the last few months. As part of the diagnosis, performed a hard reset on the broadband hub plus booster. Now it seems that the mini boxes were all disconnected from the network as a result but will not reconnect despite numerous attempts, rebooting the router each and every time as instructed on the mini and also the main box too as an attempt to get them connected. As a result, the far end of the house away from the router no longer has any wifi and so the baby monitor cameras are not working (let's hope for an uneventful night!) I've been at it for c 2 hours now - frustrations and climbing up and down stairs quietly certainly takes it toll so I've sacked it off. But has anyone got any pointers I can try tomorrow? I saw another thread mention a network reset on the mini, but I've got no menu to select it from at this stage!
Many thanks
Message posted on 05 Jun 2024 10:19 PM
Re: Sky Q miniboxes not able to join the network
Many thanks
Hi @Phil4
I know you have probably tried some of the following but try it again in the order given.
Reboot the minis as above.
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box. If you do this make sure you press the Sky router WPS button and not the router reset button. If you get the first mini connected then for other minis use WPS on the nearest Q device (main Q box or Sky Router if on Sky Broadband or previously connected mini).
Message posted on 06 Jun 2024 08:39 AM
THanks @oldfella but I think that advice is what I saw on another post - been rebooting everything, don't get to a menu on the minis to be able to do a network reset and I already have a booster, which I tried moving to improve the signal at the back of the house when the minis wouldn't connect, but not sure if that even connected itself as the wifi signal no different with or without it when stood within cms of it!
One of the minis pretty much above where the router is, so only place to put inbetween is in the floor boards!
I think it will be another call to sky again today
Message posted on 06 Jun 2024 10:24 AM - last edited: 06 Jun 2024 10:27 AM
Hi @Phil4
Assume your Booster is a Sky Q WiFi booster?
(If it trying to connect minis) also that it is connected by WPS either with the Main Q box or the Sky Router.
It should also have a full complement of Green LEDs.
All I can suggest assuming your main Q box is working is to get a mini as near as practical to the main Q box to try to connect it.
Also if you connect the booster to the main box (again??) you could try positioning it between a mini and the Main Q box. Then use WPS with that in a Network reset.
Message posted on 06 Jun 2024 11:56 AM
Thanks for your efforts @oldfella but I've been on the phone to Sky and they couldn't do anything so have booked an engineer visit for me
