Discussion topic: Sky Q minibox not connecting with tv
This message was authored by: AlanD50
My Sky Q minibox appears to be working (red and green lights as appropriate) but I am getting a No Signal message on the TV. It was fine on Thursday last (16 1/01/25) but nothing on Friday or since.
I have checked the tv on the main box, have swapped the HDMI cable for one I know works, have tried a full reboot of the whole sytem including the booster box but still nothing.
Help please!
Alan
Re: Sky Q minibox not connecting with tv
Help please!
Alan
@AlanD50 is the message no signal or no satelitte signal
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Avatar for AlanD50
This reply makes absolutely no sense to me and therefore of no help whatsoevr!!!
@AlanD50
@Laing1 is asking if the on-screen message you are seeing is 'No signal' (text which would be produced by the television set itself), or 'No satellite signal' (wording which is generated by the Sky Q box and typically indicates a satellite dish fault)
There's a significant difference in fault-finding depending on which it is
It's a rather simple question that has a massive difference...
p.s. You're not speaking to Sky customer services here
Is it on the right HDMI input?
Avatar for AlanD50
My appologies! This is the first time I have used the Community and I completely missed the answer/question. I was looking at the blurb at the bottom of the message!!!
In reply, the message is No Signal.
Nothing changed from one day  to the next in terns of the physican setup. Inh my mind this cannot have anything to do with the dish as it is a minibox and the main box is fine.
As an aside, the box is quite hot.
Avatar for AlanD50
I presume it is on the right HDMI (1) since it has been working fine up to when it wasn't!
Cycle through the inputs on the tv remote just to be sure
Avatar for AlanD50
Done, but no difference!
And if you pkug another device into that cable, you get a picture? If so I think it must be faulty
might be worth the old home 1080 home trick on the remote to reset the output resolution but doubt it will work
Avatar for AlanD50
Tried those thanks but still no luck. Thinking box may be at fault.
Yeah if you run through this, there should be a step at the end to get a replacement box
https://www.sky.com/help/articles/sky-box-problems
