Discussion topic: Sky Q minibox is not working. “No satellite signal” is shown on the screen
This message was authored by: CamClark
No Satellite Signal is shown on the screen. We have been through all of the help pages and done everything it has asked but still not working. It says our internet connection is good. Main Sky box is working but neither of our mini boxes work? Can anyone help?
Re: Sky Q minibox is not working. “No satellite signal” is shown on the screen
Hi @CamClark
Reboot the minis as above.
If the mini still does not connect try a Network Reset on the mini.  Start with the mini nearest to your main Q bo
When connecting the second mini you can use WPS on the first connected mini if the nearest.
