Discussion topic: Sky Q/minibox and Max wifi
Message posted on 07 Jul 2025 06:03 PM
Hi, I am really confused..... do the Q boxes work with the new fangled full fibre Max wifi?? thanks
Message posted on 07 Jul 2025 06:47 PM
Re: Sky Q/minibox and Max wifi
Hi @Lucy6979
If you have the latest Sky Max router then you need to connect it to to your Q box as if it is a 3rd party router.
This means you need to connect it to your Q box as follows.
First reset your broadband router by holding the Reset on the back of the router until the power light flashes green (about 10 seconds). Don't unplug or switch off your router while it resets. The power light will go green when it's done.
As the max router is like 3rd party broadband then you need to enter the SSID and password for the router 2.4 Ghz WiFi band.
Message posted on 07 Jul 2025 10:02 PM
Thanks.... seems complex, not sure if worth it.... important to have q mini working well ...
