1
This discussion topic has been answered Discussion topic: Sky Q mini will not connect. Says cannot find me on network.
This message was authored by: JANUS
Sky Q box and mini are only four months old.  Tells me cannot find me on the network so mini box does not work.  Main box is okay but screen tells me either no signal or no internet switching from one to the other several times a day.  Help please.
Re: Sky Q mini will not connect. Says cannot find me on network.
Hi @JANUS
Reboot the mini as above.
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box. If you do this make sure you press the Sky router WPS button and not the router reset button. If you have the new Sky Max router then you need to connect the WPS to the main Q box.
Hi @JANUS
