26 Feb 2024 01:38 PM
26 Feb 2024 01:42 PM
Posted by a Superuser, not a Sky employee. Find out moreYou need to check the hardware version. https://www.sky.com/help/articles/sky-software-updates
It's not the total number of mini boxes (Sky will only lend you 4) that's the issue - it's the number of concurrent boxes.
No Q box supports more than 2 concurrent mini's.
26 Feb 2024 01:50 PM - last edited: 26 Feb 2024 01:51 PM
Posted by a Superuser, not a Sky employee. Find out morehi @wendle73
The non UHD 1TB only supports 1 active mini (Hardware version 32Cxxx) the 1TB UHD box ( 32B2xxx) supports 2
As @PandJ2020 says you can only have a max of 2 active minis for SKY content - although you can use more if being used only for streaming such as Netflix & in use first
26 Feb 2024 01:58 PM
Thank you for this. It would seem that I actually have a 2TB box.
So just to clarify I've understood what you are telling me directly, are you saying that it means I can only have 2 boxes viewing independently at the same time? Ie the third box would have to watch the same programme as one of the others or wouldn't be able to watch anything?
26 Feb 2024 01:59 PM - last edited: 26 Feb 2024 01:59 PM
Posted by a Superuser, not a Sky employee. Find out more26 Feb 2024 02:01 PM
hi @wendle73
Not quite - if 2 minis are being used (unless as I mentioned one is being used for streaming an app) then the 3rd will come up with a message saying you can't use it at all
(Sorry I don't know the actual message)
Thank you very much for clarifying this. It does seem a bit pointless paying for 3 then.
26 Feb 2024 02:03 PM
Thank you very much for your help. I was hoping we could watch 3 at the same time independently but if this isn't the case then you've saved me £50+😃
26 Feb 2024 02:04 PM - last edited: 26 Feb 2024 02:05 PM
For many that is true - for some though it means they can have additional boxes in different rooms that they may not be in at the same time (e.g. Kitchen vs Bedrrom)
26 Feb 2024 02:14 PM
@wendle73 wrote:Thank you very much for your help. I was hoping we could watch 3 at the same time independently but if this isn't the case then you've saved me £50+😃
Just for clarity the main Q box doesn't count towards that number. So you can watch 3 screens at once, just not 3 minis...
26 Feb 2024 03:38 PM
Oh ok thanks, maybe it will work for me then
Ah ok, maybe it will work for me after all then. Thank you 😁
