5
This discussion topic has been answered Discussion topic: Sky Q mini showing blue screen on TV.
This message was authored by: PM52
Currently 2 Sky Q mini boxes when turned on there is a blue screen on the TVs. We are able to watch recordings and apps. The main sky Q box is working ok plus no issues with router signal. I have unplugged at mains etc but the problem is still there. Any help would be greatly appreciated.
Re: Sky Q mini showing blue screen on TV.
Hi @PM52
First try rebooting the main Q box and then when this is completely back up and running reboot the minis
Reboot the minisas above.  Start with the one nearest to the main Q box.
If the minis still do not connect try a Network Reset on each mini
You will be asked to press the WPS button on the main Q box (not the mini).
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box.  You can also use the WPS on the first mini to connect the second .
Hi @PM52
Avatar for PM52
Many thanks it worked perfectly.
This message was authored by: Lorn1
The problem is that the blue screen occurs on a regular basis. Why does it happen in the first place? Can it be stopped?
@Lorn1 it may be that your mini box is right at the edge of receiving a signal you may need a Sky booster to boost the signal to it
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
This message was authored by: Xstitcher64
I am getting this issue and already have a booster box, I have sky broadband as well. Any other advice?
