This discussion topic has been answered Discussion topic: Sky Q mini showing blue screen on TV.
Message posted on 09 May 2023 12:18 PM
Currently 2 Sky Q mini boxes when turned on there is a blue screen on the TVs. We are able to watch recordings and apps. The main sky Q box is working ok plus no issues with router signal. I have unplugged at mains etc but the problem is still there. Any help would be greatly appreciated.
Message posted on 09 May 2023 12:21 PM
Hi @PM52
First try rebooting the main Q box and then when this is completely back up and running reboot the minis
Reboot the minisas above. Start with the one nearest to the main Q box.
If the minis still do not connect try a Network Reset on each mini
You will be asked to press the WPS button on the main Q box (not the mini).
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box. You can also use the WPS on the first mini to connect the second .
Hi @PM52
Message posted on 09 May 2023 12:42 PM
Re: Sky Q mini showing blue screen on TV.
Many thanks it worked perfectly.
Message posted on 08 Dec 2023 08:04 PM
The problem is that the blue screen occurs on a regular basis. Why does it happen in the first place? Can it be stopped?
Message posted on 08 Dec 2023 08:11 PM
@Lorn1 it may be that your mini box is right at the edge of receiving a signal you may need a Sky booster to boost the signal to it
LG 49SJ 810 V UHD TV, Google Pixel 10 Pro XL mobile
Message posted on 15 Dec 2023 05:55 PM
I am getting this issue and already have a booster box, I have sky broadband as well. Any other advice?
