Discussion topic: Sky Q mini no longer connects to extender after I had to reset it.
Message posted on 01 Sep 2025 10:30 AM
My Sky Q mini locked up, it wouldn't move off standby. I found some info on how to do a reset, "switch it off on the mains, hold the reset button in while switching it on again." That got everythng working, except it will no longer connect to the extender in the hall. I've tried moving the extender slightly to make it more in line with the mini box while still having it half way between both boxes. Nothing I do works.
Message posted on 01 Sep 2025 11:05 AM
Re: Sky Q mini no longer connects to extender after I had to reset it.
The reset process likely wiped the network configuration, meaning the mini box has "forgotten" its connection to the extender. To fix this, you will need to re-pair the mini box and the extender. This usually involves pressing the WPS (Wireless Protected Setup) button on both devices in a specific sequence to re-establish the PaybyPlateMa connection. The exact steps can be found in the Sky Q user manual or on the Sky website.
Message posted on 01 Sep 2025 11:10 AM
when the box starts up it gets to the point where it asks me to press the WPS on the white extender. I've tried that lots of times and it won
t connect to it.
