Discussion topic: Sky Q mini issues over mini pushing wifi out at slow speed top trumping main router at way higher
This message was authored by: Packard999
So sky fibre with sky route in lounge ground floor c400meg, also have Q box.
upstairs with sky mini x2 unplugged is around 350.meg
plug in sky q mini, the wifi then only puts out c 15-35meg as the strongest wifi signal upstairs becomes the mini albeit it's way way slower.
due to wiring i can not hard wire with ethernet..
how can i turn the repeater function off upstairs as the main router downstairs covers upstairs with great speed, but gets beaten in terms of signal strength.
help ?
Re: Sky Q mini issues over mini pushing wifi out at slow speed top trumping main router at way highe
You could try getting one of the new Sky routers which no longer behave as part of the Q mesh. Using minis as mesh nodes is a menu option when the Q thinks it has a 3rd party router. Might have other unintended consequences.
do you need more than 35Mb wifi bandwidth?
Avatar for Packard999
Level 2 icon
What is this new router?
I was thinking of getting a power line to each mini box and then turn off the WiFi feature in mini box
or would that be a problem ?
Might work as long as they can "see" the Q via the router.
new router
https://youtu.be/_I3oExksgxQ?si=Syx5vCHAjUGrLSCW
Level 2 icon
So after a lot of graft.
i have hardwired Ethenet cable direct from sky black router to
sky Q main box
2x mini q boxes.
if i leave wifi on on the mini boxes I have the low speed
i turn off wifi upstairs on the q boxes and using a separate wifi tp link repeated I jump to 300 plus.
i still don't get why even with an Ethernet cable feed in, the Q boxes push such a low bandwidth.
also my main main feed in is guaranteed 600. But standing next to router with all other devices off I only get 450
