Discussion topic: Sky Q mini connected but says it’s not
This message was authored by: bumblebee71
My sky Q mini has suddenly started saying it isn't connected to the main box but I can tear the sound but blue screen overrides the picture
it often turns itself off and won't come back on as gets stuck on the blue screen
nothing has changed but the new problem
Re: Sky Q mini connected but says it’s not
Hi @bumblebee71 Try rebooting your main SKYQ box by turning the power off at the socket for 30 sec then turn back on to reboot, then do the same with the Mini box?
Avatar for bumblebee71
I have done that but made no difference- think I may need to ring sky - thank you for responding
