Discussion topic: Sky Q mini can't connect to network.
Message posted on 20 Apr 2025 04:35 PM
Re-started router as directed, but no solution.
Message posted on 20 Apr 2025 04:46 PM
Re: Sky Q mini can't connect to network.
hi @DK5244
The first thing I suggest is to restart your main SKY Q box :
Use the remote to place it into standby mode
Then remove the power to it (either switch off at mains or remove the power plug)
Wait at least 30s
Then re-apply the power & wait for it to fully restart - this may take a few minutes.
Once the main box is restarted do the same power down the mini box.
Message posted on 20 Apr 2025 04:47 PM
Hi @DK5244 Do you have Sky broadband? If not, then it is the Sky Q Main box that needs rebooting.
