Discussion topic: Sky Q mini boxes wont connect to new fiber broad band, router pointing to old wifi.
Message posted on 19 Nov 2023 12:14 PM
We upgraded our wifi to fiber with our existing wifi provider (not sky) Since then our mini boxes will not connect to the new wifi, they are looking for the old wifi. Any suggestions?
Message posted on 19 Nov 2023 12:23 PM
Re: Sky Q mini boxes wont connect to new fiber broad band, router pointing to old wifi.
Hi @Jo3133
Reboot the minis as above.
If the minis still do not connect try a Network Reset on each mini. Start with the nearest mini to the main Q box.
Whe carrying out the Network reset on the second mini you use WPS from the first connected mini if it is nearer than the main Q box.
