Discussion topic: Sky Q mini boxes - all channels unavailable- have reset but not working.
Message posted on 26 Jun 2025 06:55 PM
Main Sky q box fine @- but multi room mini boxes not allowing me to view to or recordings.
tried resetting / restarting and rejoining network @- nothing.
if I cannot get this working I want a refund - paying good money out for nothing
Message posted on 26 Jun 2025 06:57 PM
Re: Sky Q mini boxes - all channels unavailable- have reset but not working.
Have you rebooted your broadband, then the main Sky Q box then the mini boxes?
By the way, this is predominantly a customer led discussion forum where Sky customers are available to help other customers. You aren’t contacting Sky Customer Services by posting here.
Message posted on 26 Jun 2025 10:30 PM
Hi @MacDE
Try a Network Reset on the mini.
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box. If you do this make sure you press the Sky router WPS button and not the router reset button. If you have the new Sky Max router then you need to connect the WPS to the main Q box.
