Discussion topic: Sky Q mini box won’t get channels even bbc1 - says check subscription !!
This message was authored by: Howard251
Mini box says check subscription if it entitles you to watch ! Cant even get bbc1 and we pay fir full sky on 4 boxes !!!
Re: Sky Q mini box won’t get channels even bbc1 - says check subscription !!
Hi @Howard251
Reboot the minis as above.
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box. If you do this make sure you press the Sky router WPS button and not the router reset button. If you get the first mini connected then for other minis use WPS on the nearest Q device (main Q box or Sky Router if on Sky Broadband or previously connected mini).
