Discussion topic: Sky Q mini box staying on amber when I press the home symbol, trying to set it up on new TV
This message was authored by: ET12
I am trying to connect my sky Q minibox to a different TV, when going through the set up it stays on amber when I press the home symbol.
Re: Sky Q mini box staying on amber when I press the home symbol, trying to set it up on new TV
Hi @ET12
Have you tried pressing the Standby button (Amber led) on the front of the mini box.
If this turns the mini box on
With the mini box on with green led try completly resetting your mini Bluetooth remote.
Then make sure that you are pointing your remote at the mini box and press 1 & 3 together until the led flashes and follow onscreen instructions to re- pair to TV.
Avatar for ET12
Many thanks Mark, I will try it later and let you know how I get on.  Thanks again Eileen
Avatar for ET12
Hi Mike
Thanks so much for answering my question, I can now confirm mini box up and running.
Really appreciate it.
Many thanks
Eileen
