Discussion topic: Sky Q mini box reset step 2 of 4
Message posted on 25 Feb 2024 10:33 AM
My Sky mini box is stuck on step 2 of 4. All other boxes have been switched off and reset and when it says hold button until orange light is flashing, the light is already flashing and when I press the WPS button on the main box it is still not firing this box up! Two out of three boxes are working but the one in my teenagers room isn't! I've done everything everyone has recommended
Message posted on 25 Feb 2024 10:36 AM
Re: Sky Q mini box reset step 2 of 4
Hi @Frosty14
Is the Main Q box the nearest Q device?
You can use the WPS button on another connected mini if it is nearer.
Message posted on 25 Feb 2024 10:49 AM
The box that isn't working is on the middle floor so the same distance to the main and the other mini
Message posted on 25 Feb 2024 11:00 AM - last edited: 25 Feb 2024 11:01 AM
Message posted on 25 Feb 2024 12:04 PM
Thank you so much. I linked it with the other mini and it paired with it straight away 🤦🏻♀️ thanks for your assistance on a Sunday 👍🏻
Message posted on 07 Feb 2025 03:55 PM
Thankyou I finally managed to get the mini box working when I pressed to wps button on the main Sky Q box and after several minutes of both flashing it finally worked.
