Discussion topic: Sky Q mini box regularly loses connection to main box
This message was authored by: SteveW1969
Hi all. My mini boxes regularly lock up and won't connect to the main box. Error is can't watch tv as there's an issue with connection.... happens irregularly, at least 5-10 times per day, good Wi-Fi throughout the house. Anyone else got this problem?
Re: Sky Q mini box regularly loses connection to main box
You don't mention what sort of WiFi this is as Q to Q connectivity uses its own mesh to connect and not your WiFi.  Indeed, it could actually be your WiFi disrupting it...
Hi @SteveW1969
Reboot the mini as above.
You will be asked to press the WPS button on the main Q box (not the mini).
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box.
Failing all the above you may need a Q WiFi booster positioned midway between your main Q box and the mini.
Sky will provide these free of charge to aid Sky connectivity.
Avatar for SteveW1969
Good point. Running Sky mesh network through Sky broadband. Sky router, sky Q main box and 2 sky Q mini boxes. It's the mini boxes that both stop working - one mini box is only 3 yds from the router through a stud wall...
Thanks. I do all of that about 4 times a day and the boxes work for a bit then come up with a blue screen and the same error message after anything between 5 and 90 minutes. There is no rhythm to it nor does anything in the house change, it's quite random!
Hi @SteveW1969
Assume you are always choosing the nearest Q device when carrying out the WPS after a mini Network reset?
Yep. Same boxes worked ok on my previous (BT Whole home Wi-Fi) network. Seems to be something to do with the Sky mesh. Have got a booster and tried that in different places but the same fault (and random timings) occurs. It's been going on for over two months now and I'm starting to lose my sense of humour....
This message was authored by: SuzyM
@SteveW1969   hello, did you manage to find a resoltion to this?   We had the same issue with one of our mini boxes so Sky came out and hard wired it to the then Sky Broadband, solved the issue on that box but the wifi in the house was rubbish so we just switched Broadband provider , massive increase in speed generally but we don't have the hardwire ethernet on the mini box anymore and lo and behold the issue is back 😞    We have 2 other mini boxes which connect and stay conencted no issue.  Hardwire to the new router isnt an option given its position, we are also experiencing a sense of humour failure and the Sky boxes will be following the Sky router soon!
