Discussion topic: Sky Q mini box not working, tried settings/status, tried turning it off and on at the plug, turned
This message was authored by: Karen0426
Sky Q mini box not working. Tried turning it off and on at the plug, tried settings/status, then restarting it. Turned router off and on after 15 minutes, still not working. Box is also feeling hot so need advice please
Re: Sky Q mini box not working, tried settings/status, tried turning it off and on at the plug, turn
Hi @Karen0426
Reboot the mini as above.
