Discussion topic: Sky Q mini box not showing live tv or recordings
Message posted on 02 May 2024 05:21 PM
I have rang sky and told to wait 4 WEEKS for an engineer!! Im so angry and upset about this i have been ViP custoemr for over 5 years and they want me to not have a working tv for 4 weeks! Unacceptable! The sky pages are showing when i click on a programme the screen is all blue and nothing plays. I have rebooted and unplugged and reatarted still nothing!!
Message posted on 02 May 2024 07:01 PM
Re: Sky Q mini box not showing live tv or recordings
@Ceryslees Have you tried rebooting your main Q box ie
then
reboot your mini box
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Message posted on 02 May 2024 07:18 PM
Hi @Ceryslees
Can you still access recordings and make new ones on your main Q box?
Message posted on 02 May 2024 08:07 PM
Yes I can still record and watch recordings and live tv on the main box but not on the mini box. I've tried rebooting but nothing.
Message posted on 02 May 2024 08:36 PM
Hi @Ceryslees
Try reconnecting the mini to the main Q box.
Try a Network Reset on the mini.
